Displays information about the specified PVLAN.
name | Specifies the name of the PVLAN to display. |
N/A.
If the PVLAN is incomplete because it does not have a network or any subscriber VLAN configured, [INCOMPLETE] appears next to the PVLAN name.
The following example output displays information for the companyx PVLAN:
# show private-vlan "Engineering" -------------------------------------------------------------------------------------- Name VID Protocol Addr Flags Proto Ports Virtual Active router /Total -------------------------------------------------------------------------------------- Engineering Network VLAN: -Engr1 10 -------------------------------------- ANY 4 /5 VR-Default Non-Isolated Subscriber VLAN: -ni1 400 -------------------------------------- ANY 1 /1 VR-Default -ni2 401 ------------------------------------- ANY 1 /1 VR-Default Isolated Subscriber VLAN: -i1 500 ------------------------------------- ANY 1 /1 VR-Default -------------------------------------------------------------------------------------- Flags : (C) EAPS Control vlan, (d) NetLogin Dynamically created VLAN, (D) VLAN Admin Disabled, (E) ESRP Enabled, (f) IP Forwarding Enabled, (i) ISIS Enabled, (I) IP Forwarding lpm-routing Enabled, (L) Loopback Enabled, (l) MPLS Enabled, (m) IPmc Forwarding Enabled, (n) IP Multinetting Enabled, (N) Network LogIn vlan, (o) OSPF Enabled, (p) PIM Enabled, (P) EAPS protected vlan, (r) RIP Enabled, (T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
